"... it is possible for Windows Installer to become damaged if:
- Your computer's registry becomes corrupted.
- You or someone else inadvertently changes a registry setting used by the
Windows Installer, resulting in a problem.
- The installation of a program that uses Windows Installer (for example,
Microsoft Office XP) is interrupted.
- There are multiple instances of Setup running simultaneously, or an
instance of Setup is "blocked."
http://support.microsoft.com/support/kb/articles/Q290/3/01.ASP
To be specific, the InstallScript engine fails to start and my uninstall falls over as soon as it reages the first InstallScript Custom Action.
I have removed the condition from InstallUISequence->Engine Startup but still I get problems.
Are there any issues with regards to shipping "Microsoft Windows Installer Cleanup Utility", I would rather have a fix able to the customer if the install is in a state of disrepair than pretend it is never going to happen.
Dave.
