Hello,
I have a problem with a project created with DevStudio 9. We have tested the setup on many clients running W2K an WXP. Everything was ok.
Now there is a customer with a WinXP version that gets the following error message when trying to install our software:
Errorcode: -5009 : 0x8002802b
Errorinformation:
>Ctor\ObjectWrapper.cpp (163)
>Ctor\ObjectWrapper.cpp (384)
>Kernel\Component.cpp (1161)
>Ctor\ObjectWrapper.cpp (34)
>Ctor\DriverWrapper.cpp (31)
>Kernel\Component.cpp (1150)
>Kernel\CABFile.cpp (384)
>SetupDLL\SetupDLL.cpp (1655)
$9.1.0.429PAK
@Windows XP (2600) BT_OTHER 5786.30479
Has anyone a suggestion what might be the problem?
Best regards
Frank
Errorcode -5009
timbuktu
, Mar 24 2004 11:52
Posted 24 March 2004 - 18:53
I found this inside IS help. It suggests you contact tech support.
-5009 The schema Summary Stream must be 200 or later. Check the InstallShield Knowledge Base for information about this error, or request technical support.
Posted 25 March 2004 - 12:07
| QUOTE (Ozone @ 2004-03-24 18:53) |
| I found this inside IS help. It suggests you contact tech support. -5009 The schema Summary Stream must be 200 or later. Check the InstallShield Knowledge Base for information about this error, or request technical support. |
I think the error code in IS manual refers to the build process only.
"The following table contains a listing of error and warning codes that may occur during the build process, and troubleshooting tips should they occur."
My problem occurs only at runtime.
I have contacted tech-support. If we find an solution I will let you know.
Posted 12 April 2004 - 19:47
Hello again,
maybe the solution to my problem will help someone in the future. On the target machine perform the following steps:
- clean out the TEMP directory
- delete the... <PROGRAM FILES>\Common Files\InstallShield\Professional\RunTime\09
- Make sure you have sufficient COM permissions. For information on how to troubleshoot this, see KB article... http://support.insta...ticleid=q104986
Best regards
Best regards
Posted 12 October 2006 - 18:16
Thank you very much for the posting.
This article has been very useful in helping customers.
I guess the future is here.
Posted 12 October 2006 - 18:34
As the saying goes: "... the future is here, but it is not evenly distributed."
