Error 1721 when trying to install MySQL
Posted 16 July 2003 - 08:54
I have this problem since 2 days and cannot figure out why.
I want to create an installation which will install (1) My application (2) JRE and (3) MySQL
I did a Basic MSI Project with Install Shield Dev. 8.
(1) is working nice.
I used CA with a property variable poiting to the right exe file for (2) and (3).
(2) works fine, with (3) I have:
Error 1721: There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support or package vendor.
I am sure that my property variable is correct. I was wondering if during installation something is enabled/disabled which causes the installation of MySQL not to work. Manually when I launch the installation it works...
Any idea?
Thx,
stoss
Posted 16 July 2003 - 09:25
- make sure your custom action (3) is in user interface sequence
- try to run the MySQL setup directly to see if it works at all
- generate a log file to get more information about the problem
Which operating system are you on, and what is the type and parameters of yopur custom action (3)
Posted 16 July 2003 - 09:41
Hi Stefan,
Thx for ur quick answer.
About ur suggestions:
My custom action is used by a dialog box, DoAction on a button. The condition
is "1".
This dialog box is inserted in Sequence: User Interface after ExecuteAction
(2) which is in the same dialog box (other button) works fine...
-try to run the MySQL setup directly to see if it works at all
Tried it...it works ! Tried also to do the operations with different
versions of MySQL and always the same error
-generate a log file to get more information about the problem
How can I do that?
I am on W2K Pro, Administration rights
Type and params of my CA:
Executable Property: MYSQL_INSTALLATION_EXE (which is the complete
path of the installation file of mysql)
Command Line:
Return Processing: Sunchroneous (Check ExitCode)
In-Script Execution: Immediate Execution
Executions Scheduling: Always Execute
Use 64 Bit Scripting: No
MSI Type Number: 50
Posted 16 July 2003 - 09:54
Change the CA to ignore the return code. Does it work then?
Also: is MySQL installed after your setup aborted?
Posted 16 July 2003 - 15:24
I turned the CA to ignore the error code and now I don't have any error
but nothing is passing.
MySQL installation is not lauched and nothing is installed on my HD.
Note: I tried on 2 different comps and I have the same problem.
I did put a notepad.exe in the path where is the setup.exe of mysql installation
and changed the property variable to point to notepad.exe and this works. So I guess my path and the whole think is correct.....but setup.exe of mysql doesn't want to be launched !!!! Don't understand why...
Did enable the logging options but I can't see anything which can help me.
Something else when doing my project (Basic MSI Project) I used the wizard of InstallShield...just 4 u to know in case...
Posted 16 July 2003 - 21:56
Can you post the log lines, from the starting of the CA until the failure?
Posted 17 July 2003 - 11:02
So I did the operations u suggested to know:
I try to launch the MySQL installation manually when my Install Shield setup is under process (on the welcome dialog, on my dialog from which I push the buttons to launch the installations, on the final dialog) and manually it works
Here is the log when clicking on the button which launch normally the MySQL installation:
Action start 11:19:12: LaunchMySQLInstallation.
Info 1721.There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personnel or package vendor. Action: LaunchMySQLInstallation, location: C:\INTENT\MySQL\SETUP.EXE, command:
Action ended 11:19:13: LaunchMySQLInstallation. Return value 1.
What I will do is a new project with just this custom action to see what it does...
can't understand what can be the problem.
Anyway thx for ur help so far...
Posted 17 July 2003 - 11:25
Did new project with just this CA and again same problem....kinda lost, don't understand I am not the first person who tries to launch a MySQL installation from my InstallShield setup...
Is that possible that MySQL installShield setup was defined in a way to prevent other setups to launch it??
Don't have any idea...will post my issue on MySQL forum or something to see what they say...
Posted 17 July 2003 - 15:38
One more thing you can try: insert the custom action directly in the UI seqence instead of launching it from a button.
Posted 18 July 2003 - 07:25
With InstallShield 5 the setup.exe only extracts the real setup engine and support files and then dies. So your main setup continues (maybe even deletes the MySQL setup files) while the MySQL setup is still running. /SMS will tell setip.exe to wait until the MySQL installation is completed.
Posted 18 July 2003 - 11:52
Hi Stefan,
What I did is that instead of using the CA with an exe file, I did implement
functions which uses LaunchAppAndWait function. Did CAs which uses these
install scripts.
When inserting my dialog box with the DoAction in the User Interface Sequence after ISStartup
it works fine, (JRE AND MySQL installation r launched).
If I insert my dialog box after ExecuteAction it doesn't work anymore...
Any idea?
Thx
Posted 18 July 2003 - 12:05
Posted 18 July 2003 - 13:45
Now an other question as I told you I have my main application JRE and MySQL to install and what I did is a dialog box (we call it D1) from where u can launch MySQL and JRE. I want to extend this dialog box to be able to Launch the installation of my main application too.
D1 ==> (Op1) User choose to install Main application ==> Normal Installation is launched ==> back to D1
==> (Op2) User choose to install JRE ==> CA running JRE setup is launched ==> back to D1
==> (Op3) User choose to install MySQL ==> CA running MySQL setup is launched ==> back to D1
The Main application is the ONLY feature of my Basic MSI project.
D1 is blocked when OpX is under process. My question is how can I choose to proceed on Op1 on a new "child" Dialog Box ! ( I used spawnDialog on a push button but it doesn't seem doing what I want). This New child dialog Box will follow the Sequence initially established by my MSI project...
Posted 18 July 2003 - 14:29
If you are looking for a sort of front end to act as an "umbrella" or wrapper for these setups, you should do it outside of msi. See the tools at http://www.installsi...tt_cdbrowse.htm
Posted 23 July 2003 - 09:20
Hi Stefan, I used installScript to run MySQL and it works...can't find why a CA launching an EXE doesn't work...anyway thx for the help and time!!!!
