Hey guys, in an install I need to install MDAC_Typ.exe and then Windows Media Player. I've found that if I reboot after having installed both MDAC and Windows Media Player that numerous Windows Media Player components fail to register. Thus, I want to install MDAC and then force a reboot before continuing with the installation. Can anyone recommend a way to do this? I've tried using a ForceReboot, but I'm not having much luck in this department. By the way, this is a Standard Project. Any suggestions would be much appreciated. Thank you.
Forcing a Reboot
CGreg
, Mar 11 2002 20:25
Posted 12 March 2002 - 14:48
There are a couple of ways to achieve this. I use
szTitle = "System Reboot";
szMsg = @FINISH_COPY + @PLEASE_REBOOT;
RebootDialog(szTitle, szMsg, SYS_BOOTMACHINE);
Please note that if you want to continue after the reboot, you must set BATCH_INSTALL=TRUE prior to the reboot.
Hope this helps.
Marie
Hope this helps.
Marie
Marie Tupps
Posted 12 March 2002 - 14:51
Hope this helps.
Marie
Hope this helps.
Marie
Marie Tupps
