I have a problem with favor source :
say I have a file a.exe which reads b.txt from same folder.
Now if I make two components
a : a.exe : favor source
b : b.txt : favor local
a.exe is installed at source and is able to read b.txt .
Now if I do like:-
b : b.txt : favor source
then a.exe is unable to read b.txt , though both are installed at source.
any clarification???
problem with run from source.
saeed_a
, Jun 17 2004 23:57
Posted 18 June 2004 - 09:15
I guess that a.exe is not actually written to load b.txt from the same directory as a.exe but from the curent working directory.
Posted 23 June 2004 - 12:12
Maybe a.exe reads from the registry where to find b.txt? If there is a registry-entry pointing to [INSTALLDIR]b.txt then it will allways point to the local folder. In order to point to the place where b.txt actually is, it should point to [#b.txt] (where b.txt is the file id).
Dick Nagtegaal
