I have a dialog with a license agreement, a checkbox and 2 buttons below it:
[Back] | [Yes] | [No]
The [Yes] button is disabled at first and needs to be enabled when the user checks the checkbox, indicating that he has agreed to the terms and conditions.
How do I enable/disable the [Yes] button based on the click event on the checkbox?
FYI, I have an InstallScript MSI project. I found an article that talks about this:
http://www.installsh...icles/check.asp
But this only applies to Basic MSI projects, and I can't see to do the same thing to my InstallScript MSI project.
how to respond to checkbox event?
shahedC
, Dec 28 2004 19:45
Posted 29 December 2004 - 18:44
I was able to solve this problem by defining a custom dialog using EzDefineDialog() and lanching it using WaitOnDialog().
I checked the return value of WaitOnDialog repeatedly in a loop to respond to events of its controls (radio buttons, push buttons, etc)
My dialog box now looks like this:
[ License Agreement text]
o I agree
o I disagree
[Back] [Next] [Cancel]
Now, it works as I want it to, but I would like to have the "I agree" radio button selected as a default.
How do I select a radio button as a default? I looked through all the properties. but couldn't find anything.
UPDATE: Ok, I just found out that CtrlSetState() can be used to check a radio button, so this works for me.
o I agree
o I disagree
Edited by shahedC, 29 December 2004 - 18:56.
Posted 29 December 2004 - 18:46
Also, I would like to have the Next button disabled until the user clicks I agree.
How do I disable and enable pushbuttons programatically through InstallScript?
I tried looking through the documentation, but it seems that you can only call ENABLE() and DISABLE() for automatically generated buttons on non-custom dialogs.
Posted 03 January 2005 - 08:19
Hi Shahid,
For your 1st question, that is how to make a radio button selected by default. u can specify the value of the radio button which u want to be selected as default in the radio button group's property value in the Property Manager view.
Or another approach, is through script. U r using WaitOnDialog(), in that use CtrlSetState() to select a radio button as default.
I hope u can achieve what u want through any of the above approaches.
Regards,
Vishnu
Regards,
Vishnu
