I would like to use only two components. In event OnFirstUIBefore() there is the calling SdComponentTree() dialog box. The second component is "normal" component (selectable - deselectable). The default value for it is deselected.
The first one must be selected always. I want this component make unselectable (It may be gray).
I have set the FileNeed property to Critical in Component Property Sheet.
The help contains:
Write script code that retrieves the value of this property and displays a message accordingly.
Retrieve the value of this property by calling ComponentGetData with the third parameter set
to COMPONENT_FIELD_FILENEED.
I ask where to write this script? I would like this component to be selected and gray OR if enduser
deselects this component then to show an error message immediately.
Has anyone any idea?
kari_hun
Components FileNeed Critical
kari_hun
, Jul 07 2003 12:51
Posted 14 July 2003 - 08:31
By this time I found a solution for this problem:
I created a dummy component which installs nothing.
I set this components Required Component property to my first component (which I want to be always selected).
I marked the dummy component Visible property to No.
And the result is Bingo.
kari_hun
kari_hun
