I am using ISDev 8.0 Basic MSI and I am trying to uninstall the installed application thru Control Panel -> Add/Remove Programs, but unfortunately it is not deleting all the files in installed folder.
I observed this scenario when I tried to uninstall after doing a Major upgrade. One thing I observed is : In the component properties ALL the components I created have a property as Shared. Any suggestions ????
UNINSTALL
cherukus
, May 04 2004 14:00
Posted 25 June 2004 - 22:31
i have this same problem. were you able to come up with a solution?
Don Tasanasanta[br]Configuration/Installation Eng
Posted 26 June 2004 - 14:06
This could be a complication that only exists on your build computer (a failed setup may at one point have registered components and now the components appear to be still needed after the uninstall of your product). Try to do an install on a fresh system and then an uninstall.
