Hi all ,
I have a requirement that 2 check-box there in a custom dialog box.Default all box are checked.If i unchecked the checkbox then New feature will be not to be install.same thing happen for second checkbox.Please suggest how we can solve this problem?
Create a Basic msi project using a custom dialog
Posted 04 September 2014 - 09:42
Posted 04 September 2014 - 15:50
Moving question to Basic MSI forum
Posted 04 September 2014 - 15:52
To make the CheckBox checked, assign a value to its associated property in the Property table.
To select/unselect the related features, add control events AddLocal and Remove to the "Next" button, like:
AddLocal Feature1 CHECKBOX1
Remove Feature1 Not CHECKBOX1
Posted 04 September 2014 - 18:58
Stefan, are you sure CheckBoxes don't require the property to be undefined instead of just using Not, as in CHECKBOX1= {}? Perhaps this is different in newer versions of Installshield, or I am thinking of Installscript.
Update: as far as I can see Installshield probably deletes the property automatically now - I remember struggling with this in earlier versions. To clarify, the deal is that the property isn't checked for its value, but whether it is defined at all or undefined (not existing in the MSI session).
Not correct:
- (CHECKBOX = 0) OR (CHECKBOX = 1)
Correct:
- CHECKBOX OR (Not CHECKBOX)
Similar post here: http://forum.install...showtopic=16471
Edited by Glytzhkof, 04 September 2014 - 19:18.
Posted 12 September 2014 - 15:32
The comparison CHECKBOX1= {} should give the same result as Not CHECKBOX1, so you can use the style you prefer. And yes, the value of the property doen't matter, which can be confusing. Thanks for the additional clarification Stein.
