Like to what is the optimum method to Enable/Disable the Outlook 2007 plug-in
Example:
Enable
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\Test.TestFormat
LoadBehavior=3
Disable
LoadBehavior=0
Link: http://msdn.microsof...px#LoadBehavior
Thanks in advance for your help!!!
skj
, Feb 09 2010 13:50
Posted 10 February 2010 - 12:57
Use 3, that means that the addin is automatically initialized when Outlook is started. Option 0 means that the user must press a button in a dialog far, far away.
Note that this setting only affects the starting behavior of Outlook. When Outlook is already running, you should connect with Outlook (through COM) to access the running instances - or tell the user to restart Outlook.
