I've added MDAC 2.7 to a basic MSI project. The project builds fine, but running the MSI Validation suite through DevStudio, an error is reported:
ICE18 Error
KeyPath for Component: 'MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF' is Directory: 'INSTALLDIR'. The Directory/Component pair must be listed in the CreateFolders table.
http://dartools/iceman/ice18.html
Component
Directory_ MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF
So my question is if I have a component table that has an AllOtherFiles component that would suggest this would be the merge module component(?) do I need the add the component guid to the CreateFolder table along the the INSTALLDIR path or another path ?
What are the implications of this? if I remove my application, will MDAC also be removed when this folder is removed?
I feel I've missed something here as the installation is simple, one exe, one dll and one UDL supporting file and a few VB mergemodules. Should DevStudio create this entry in the CreateFolder when I add the mergemodule automatically ?
MDAC2.7 Merge module ICE18 problem
kevbowuk
, Apr 19 2004 15:04
Posted 19 April 2004 - 16:37
Assuming that your application files will be installed to INSTALLDIR you can ignore this message.
Posted 19 April 2004 - 17:08
OK Thanks.
I've added the component MDAC27.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF the the CreateFolder table with INSTALLDIR as the Directory and it validates ok now.
Thanks again.
Thanks again.
