i build a basic msi installer then i have installed it using group policy..
my problem is i cant uninstall it? is it possible that the problem is in basic msi or the problem lies on the installation process of group policy?
Limited user uninstall
haroldxious
, Jan 24 2007 09:17
Posted 25 January 2007 - 01:17
| QUOTE (Glytzhkof @ 2007-01-24 10:32) |
| First of all you should generate a log file: http://www.installsi...ifaq/a/1022.htm |
this is only for installers that is louched by setup.exe
Posted 25 January 2007 - 05:57
Globally for all setups on a machine
You can also globally turn on Windows Installer logging for a machine. To do this create the following registry entry:
[HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Installer]
"Logging"="voicewarmup"
"Debug"=dword:00000007
This will generate log files named Msi*.log where * is a random number in the TEMP directory for each MSI based setup. The meaning of the flags in the value are documented in Microsoft knowledge base article Q223300. Note that you should use this only during the trouble shooting phase because it will have adverse effects on system performance and disk space.
