Dear All,
Iam Facing Setup error While installing Dotnet Framework 3.5. Following are the error log for
Error Log:
[01/15/09,19:08:19] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[01/15/09,19:08:46] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[01/15/09,19:49:53] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[01/15/09,19:50:16] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[01/16/09,11:02:14] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[01/16/09,11:02:32] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
[01/16/09,11:56:24] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1603
[01/16/09,11:56:47] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed.
>i tried by removing sqlserver and other dotnetframework also.but still problem Pursues.
regards
User
Dotnet 3.5
devstudio.2007
, Jan 16 2009 09:31
Posted 17 January 2009 - 17:51
Take a look at Aaron Stebner's weblog. He frequently posts trouble shooting tips for .NET framework installation. http://blogs.msdn.com/astebner/
Posted 21 January 2009 - 09:30
Thanks For your reply.But i Cant Solve this Problem.Still iam trying??????
Posted 22 January 2009 - 13:38
Dear Sir,
Problem Solved i tried another package using Following Link.see this and Let me know if any Concern.
Link:http://www.d60pc.com/2009/01/16/microsoft-net-framework-35-sp1
regards
Narayan
regards
Narayan
Posted 22 January 2009 - 16:47
I don't know that language so I'm not sure what the text on that page says.
But you should only download the .NET Famework (or any other redistributable) from trusted web sites, in this case microsoft.com, not some third party site. You'll never know which modifications they may have made to the file.
