Hello... I would like to know how can I stop or kill an .exe before that uninstall my application or just in the moment to uninstal the application?
kill a process
aranda
, May 24 2005 20:57
Posted 25 May 2005 - 09:00
Take a look at sample "List and Shut Down Running Applications" at http://www.installsi.../en/isp_ext.htm
Posted 07 November 2005 - 06:23
I use findwindow() in the OnUninstall() to find the App , then use sendMessage to close the App, but it seems that if you click the setup.exe to uninstall the App,it don't work.
it don't execute the Oninstall(). So where should i place the findwindow() funcation ?
Posted 07 November 2005 - 07:35
If you want an overkill you might try pskill.exe from system internals: http://www.sysintern...ies/PsKill.html
Posted 08 November 2005 - 11:51
I have never used it, but I think you should be able to use a "run EXE file" custom action with the appropriate command line specified.
