Is there anyway to turn off the "Maintenace Finish" dialog at the end of uninstall/reinstall? What I try is to bypass the Maintenance Mode but still let the users to uninstall or install (like it's never been installed). The problem is that it can run accordingly to what I want but the "Maintenance Finish" dialog appears. I want the "Setup Finish" to be displayed instead of the "Maintenance Finish".
Can some body help?
Thank you very much in advance!
"Mainteance Finish" Dialog
TDO2002
, Jan 22 2002 20:50
Posted 22 January 2002 - 21:43
You can change the "Maintenance Finish" dialog's appearance by changing the values input into the SdFinishEx command in the OnMaintUIAfter event. The variables that you are probably interested in are szMsg1 and szTitle.
For more information on customizing maintenance mode you may want to look at the following InstallShield knowledgebase articles: Q104327 and Q104414
