Please help me. I would like to know how I can select the feature from the drop down menu of installation feature in a command line.
I'm using a separate wise install script to run the silent install(calls the actual product installer) which calls the INI file with all the information needed during installation. e.g.(installation path)
The problem is the user wants to select the featured components to be installed from the actual product installer. But for now only the default feature are installed as no dialog is displayed.
Is there a way or a special property where I can identify if the feature is selected using a wise script during installation or in a command line?
ex. If Replication = Yes
featured component "Replication" will be installed
Else
default feature
Thank you so much. I just need it badly.
Calling featured component using a silent install
badzoy07
, Oct 14 2008 10:50
Posted 14 October 2008 - 14:53
MSIExec /i [path_to_MSI] ADDLOCAL="Name_Of_Feature_To_Install"
