as i am thinking of a work around to do this, i have seen some post that i can change the value of the MSI DB to hide a feature at runtime.
I have used this. I call a CA in immediate execution to change the value in the feature table..
// Obtain a handle to the active database
hDataBase = MsiGetActiveDatabase(hMSI);
szSQL = "Select `Display` FROM `Feature` WHERE `Feature` = NewFeature1'";
nResult = MsiDatabaseOpenView(hDataBase, szSQL, hView);
nResult = MsiViewExecute(hView, NULL);
nResult = MsiViewFetch(hView, hRec);
nResult = MsiViewModify(hView, MSIMODIFY_DELETE, hRec);
nResult = MsiRecordSetInteger(hRec, 5, 0);
nResult = MsiViewModify(hView, MSIMODIFY_INSERT_TEMPORARY, hRec);
This works fine...but after i have tested the UI again and again i have comeup to see an error....
after executing the CA then on the selection tree..when i click back error 2711 appears telling that specified feature name not found on the feature table..
i know this is because of the MSIMODIFY_DELETE.
is there any workaround on how error 2711 will not appear?
MSIMODIFY_UPDATE doesnt work for me.
Hiding a feature at runtime
haroldxious
, Jun 05 2007 09:26
