I have a product install scripted using installscript. Can you please tell me what dependencies the product will have wrt install shield engine?
Also, should the product carry installshield engine with it to be installed? What are the various problems if the product bundles installshield engine with it?
Install script engine
aarthi_m
, Oct 21 2005 06:23
Posted 23 October 2005 - 15:11
Yes, you should bundle the InstallScript engine. I believe this is done automatically.
Posted 24 October 2005 - 08:09
Thanks for the reply.
What will be the problems if the product carries Installshield engine along with it?
What will happen if the installation of the engine fails? Will the product installation also fail?
Posted 24 October 2005 - 12:44
| What will be the problems if the product carries Installshield engine along with it? |
I don't expect any special problems (other than those you may see with other runtime engines)
| What will happen if the installation of the engine fails? Will the product installation also fail? |
Yes, the engine is required.
