Hi Everyone,
I'm experiencing something a little strange. I need to do some things with the output of the SdWelcomeMaint function/dialog. I know this dialog appears during the OnMaintUIBefore event. So, I decided to customize this event.
Before modifying this event, things (like file transfers) appeared to be working normally. However, after putting in some code in OnMaintUIBefore, I saw the dialog I wanted, but suddenly the other things stopped working properly. When I comment out the OnMaintUIBefore() things go back to working normally.
I was wondering what is required to be put into this event to keep everything else working during the maintenance operation?
Thanks in advance,
Mike Goldweber
Here's an example of my code:
OnMaintUIBefore
halciber
, Apr 14 2006 17:17
Posted 14 April 2006 - 17:17
function OnMaintUIBefore() string szOutput; number ret; begin ret = SdWelcomeMaint ("", "",MODIFY); switch(ret) case 301: //modify szOutput = "Modify"; case 302: //repair szOutput = "Repair"; case 303: //remove all szOutput = "Uninstall"; endswitch; MessageBox(szOutput, INFORMATION); //what do I need to add here to keep a repair, modify, or remove all working //properly? end; |
Edited by halciber, 14 April 2006 - 20:16.
Posted 14 April 2006 - 20:16
I did some more digging after I posted the message, and I discovered the following functions:
FeatureReinstall();
FeatureRemoveAll();
Once I added them, things worked perfectly again! See the revised code below.
Enjoy,
Mike Goldweber
FeatureReinstall();
FeatureRemoveAll();
Enjoy,
Mike Goldweber
//------------------------------------------------------------------------ Revised example: function OnMaintUIBefore() string szOutput; number ret; begin ret = SdWelcomeMaint ("", "",MODIFY); switch(ret) case 301: //modify szOutput = "Modify"; case 302: //repair szOutput = "Repair"; FeatureReinstall(); case 303: //remove all szOutput = "Uninstall"; FeatureRemoveAll(); endswitch; MessageBox(szOutput, INFORMATION); //what do I need to add here? //ANSWER: Nothing!! end; |
