Hi all
Is there any exe which would un-compress a compressed .msi file.
i am not able to find any help. I went through the msiexec /a command which would do un-compression but that is not i want.
is there any tool which does the same thing while creating a patch the installshield patch genaration wizard would do when given any compressed msi file (i asks for path where it would un -compress the compressed msi file)
thanks in advance
sarfu
Un-compressing .msi file
sarfu
, Apr 20 2007 16:29
Posted 23 April 2007 - 09:20
| I went through the msiexec /a command which would do un-compression but that is not i want. |
So what DO you want then? Maybe I don't understand your problem.
Posted 23 April 2007 - 12:37
thanks for kind reply stefan
the problem with the msiexec /a command is i can't mention the path where it should un-compress my .msi file, in fact it pops up a dialog asking for the path where it can un-compress it. But since i am tyring to build the patch with the script and no UI what so ever ( command line) i am not able to mention the msiexec /a msiname.msi the path where it should un compress. It throws up command line parameters dialog what are the legal commands
but with msiexec /a there is no third parameter to mention the path where it should un-compress the .msi file. Please correct me if i am wrong. or is there a way to give parameter so that it can un-compress the .msi file in desired location.
thanks in advance
sarfu
thanks in advance
sarfu
Posted 24 April 2007 - 17:53
Try this:
msiexec.exe /a your.msi TARGETDIR=C:\whatever\you\want /q
where /q makes the action silent.
Posted 25 April 2007 - 05:30
Thanks for kind reply stefan
It really did work.
but one thing i observed is i cant give the relative path in TARGETDIR. but this can be done by other means.
the silent un-compression is happening fantastically. thanks once again
sarfu
It really did work.
sarfu
