Hi
Problem is very simple I had used askpath function and choose a directory which will be in script variable svResultPath, Then I have used file groups that has two asp files and component is mapped to destination of Script defined folders that is created by me svResultpath. When i try to run the setup i am getting "error occurred during the move data process :- 145"
Component: Help files
Filegroup : HelpFiles
File:
Help needed?.
sPath="C:\\";
nResult = AskPath (szTitle, sPath, svResultPath);
if (nResult = NEXT) then
if (ExistsDir (svResultPath) = 0) then
bTargetDirOk = TRUE;
else
if (AskYesNo ("Folder does not exist. Create it?",YES) = YES) then
if (CreateDir (svResultPath) = 0) then
endif;
endif;
endif;
else
sPath="";
svResultPath="";
goto Dlg_SdAskDestPath;
endif;
when i try run the set up i am getting " error occurred during the move data process :- 145"
Jai
neyjai
, May 26 2005 07:43
