1. Multilanguage Basic MSI Installation
2. Happens during patch only (7.14.1 ->7.14.2)
2. Only on a non english system
3. Happens before UI sequence
Error LOG dump
<LOG>
2229 3 Launch condition
I (s) (7C:BC): Note: 1: 2254 2: 3: LaunchCondition
MSI (s) (7C:BC): Note: 1: 2229 2: 3: LaunchCondition 4: SELECT `Condition`, `Description` FROM `LaunchCondition`
MSI (s) (7C:BC): Transforming table Error.
DEBUG: Error 2229: Database: . Could not load table 'LaunchCondition' in SQL query: SELECT `Condition`, `Description` FROM `LaunchCondition`
ÄÚ²¿´íÎó 2229. , LaunchCondition, SELECT `Condition`, `Description` FROM `LaunchCondition`
MSI (s) (7C:BC):·: Product 2229. , LaunchCondition, SELECT `Condition`, `Description` FROM `LaunchCondition`
16:50:16: LaunchConditions¡
MSI (s) (7C:BC): Doing action: ISCleanUpFatalExit
<LOG END>
any ideea is more than welcome
Error 2229 during patch
Giurcanu Daniel
, Jul 07 2004 09:15
Posted 08 July 2004 - 09:13
Really no good idea here, but I don't think MSI files are Unicode, so I suppose you could get problems if you insert exotic characters in MSI tables. What does your LaunchCondition table look like?
Posted 08 July 2004 - 15:09
Do you have a more verbose log file? This looks like a Debug error, which usually would not cause your setup to fail. It also looks like the log is corrupted, e.g. this:
should pobably be:
MSI (s) (7C:BC): Note: 1: 2254 2: 3: LaunchCondition
Also you men tioned that this happens before the UI sequence. However the log indicates that the installation is already in the Server process, which means it's the Execute sequence.
should pobably be:
