What do I need to do after checking the box for the appropriate Merge Modules in Redistributables in InstallShield Developer 8.0? Must I add some Custom Actions in the Behavior and Logic section? I hope you, who have done this successfully, will direct me (as well as other readers) on the basics.
Installing Merge Modules in Developer 8.0
PBDeveloper
, Dec 18 2002 15:33
Posted 18 December 2002 - 15:33
Sadly, my Merge Modules are not getting installed.
Posted 18 December 2002 - 22:09
When I create a Basic MSI Project, the installation works just fine. So, what must be added to the InstallScript to cause the Redistributable Merge Modules to be acted on by the Windows Installer? Is there an example somewhere?
I also want to be able to test the system to see if an earlier version of the DLL is resident.
