For example, the file "input_next.gif" has a short filename of "INPUT_~2.GIF" in the administrative install image of the new version, and "INPUT_~3.GIF" in the image of the old version.
ISD7's direct table editor shows that these files are recorded with the short filename of "INPUT_~1.GIF" in the FILE table of both msi databases. Actually, every file seems to have ~1 in its short filename in the msi table, despite the fact that this would causes duplicate in the same directory.
This problem occurs for many files, and needlessly bloats the size of my patch.
How can I control the short filenames, to make them consistent and avoid this failure?
PS: here is an exerpt from the patching log:
| Code Sample |
| WARNING (11): File.FileName mismatch between Upgraded ('INPUT_~2.GIF|input_next.gif') and Target ('INPUT_~3.GIF|input_next.gif') Images means old files may be orphaned. File Table Key: input_next.gif1 Patch API could not create a small patch; using whole upgraded file. |
