Msi in Active Directory
Posted 14 July 2004 - 05:35
I have created a basic msi package. I publish it through the active directory of windows 2003 server (Maximum UI). I was able to see it on the Add New programs in the Add/Remove program applet on an XP client. I can run the installation; however, when I change the default location of the installation. The files will be copied in the default location. Looking in the log file I noticed that the client properties don't get copied to the server properties. It seems like The server installation get its props from the original package. Is this the default behaviour of deploying over the active directory. I am using alot of properties that I change during the interface session that I want them to be available during the server session. What can I do ?
Thank you all
Posted 14 July 2004 - 15:32
Posted 15 July 2004 - 05:01
Posted 15 July 2004 - 17:16
Thank you very much ..... This is what I missed ..... Also, your advice led me to discover that by setting the EnableUserControl Property to 1. All the public properties will be passed from the interface sequence to the execution sequence.
The only exception I found is the ALLUSERS property. which don't get updated if you publish the package to certain users. So, if we set the ALLUSERS to 1, The ALLUSERS property will always be missing. This maybe because of the active directory forcing the installation to be for certain user not for all of them.
Do you think there is a way to force the installation to be for all users even if we publish it to certain users ?
Thank you very much
Posted 15 July 2004 - 21:11
Posted 16 July 2004 - 14:57
Yes assigning the software to a specific machine will do it. However, we want to allow certain users to choose the machines they want to install the product in. I am not sure if it is possible with the current msi technology.....
Thank you
Posted 20 July 2004 - 09:02
If you have to be complient with AD installations, I suggest you rewrite your setup (and possibly software) to be compatible with per user installations.
Posted 20 July 2004 - 13:32
Thank you for replying,,,,,,
Can you please tell me what changes should I make to enable my setup, application to support per user instalation? Is there any special guide that help us to build per user setup? Currently when I install my application to two different users. It works but when I uninstall the application, it is removed from both (the files and HKLM).
Thank you very much
Posted 21 July 2004 - 09:57
Check the MSI with Orca. Look out for ICEs that report problems like "the key field of the component is per-user, but the component contains per-machine items" (something like that, it's a long time ago). Split up these compenents. Carefully select the key field of each component.
Another consideration is changing regkeys, install them to HKEY_SELECTABLE (root=-1) instead of HKLM. You need to change the software as well, it should attempt HKLM and HKCU as well. This is not really necessary, but recommended when the keys contains certain setup information: after all the software is installed twice, and may have had different properties.
Other considerations:
- Check the behavior for feature differences between the installs - I think it's possible that different users install different features. I don't allow this on my setups, though.
- Check the behavior for installs to different paths. Again, I don't allow this.
- Check upgrading.
Most of all: run ICEs and take care of all errors and warnings.
Posted 21 July 2004 - 12:21
Per user installs should essentially affect COM registration, shortcuts, and ARP (Add/Remove) registration plus any data installed to the userprofile (installing files here is a big NO NO! - it causes problems on terminal server and for people repackaging your setup). http://msdn.microsof...stallations.asp
Posted 21 July 2004 - 12:22
Posted 22 July 2004 - 08:28
BTW The validation code is ICE57, see
http://msdn.microsof...setup/ice57.asp
Posted 22 July 2004 - 08:44
Posted 03 August 2004 - 22:55
Sorry for being late. I was busy with other development.
Zweitze you said that "Well, that implies a problem: components are installed twice (you installed for two users) but after the first uninstall, the components are removed."
I am not sure about that because I tried to publish MS project 2000 in the active directory. I did the installation for two different users (user A and B)on the same machine. They copied the files to the same default folder. I uninstalled the project from one user(User A). All the files were removed from the folder. When User B tried to launch the MS project application, it was reinstalled......
The same behaviour was seen with the visio viewer 2003.
So I guess this is the expected behaviour in that scenario...
Regarding my application.....
I am not sure about the ICE57 ERROR. I have one of them with one component where I have both HKLM and HKCU entries in the same component. Now If I isolate them into two isolated compoonents and then I do a per machine installation? will the component with the current user registry entries be installed.And what about the per machine component would it be installed with a per user installation.......
Thank you very much.....
Posted 04 August 2004 - 16:05
About your app:
I recommend to split up that particular component into two components, one with HKCU entries, and one with HKLM entries.
In case of a per machine installation, the HKCU component will be installed for the user performing the installation. Other users won't have that key. However, if you mark one of the HKCU values as keypath, and the software calls RegOpenKey, RegQueryValue (don't know which one), the installer will 'repair' the missing entries for that other user.
Note this scheme only works when you set the keypath accordingly.
The other way around (per machine components in per user installation) always works as expected: The component is installed.
I know that ICE57 is not that trivial, but I fixed mine, everything seemed to work much smoother.
Disclaimer: Dus to other reasons, we no longer attempt to install keys in HKCU. It's mostly HKEY_SELECTABLE now, and sometimes in HKLM. The software that needs HKCU comes up with default values.
Posted 04 August 2004 - 17:02
Do you know where can I check for the component refrence counting. Is it possible to enable/disable it?... I know that we can check the 'SharedDlls' key in the registry in (HKLM\software\microsoft\windows\currentversion\sharedDLL) but where do we have to check for components counting...
Also if you can have a look at the thread "Change button for non-admins " I will be very thankful
Thank you very very very much
Posted 05 August 2004 - 13:37
The property 'Shared' in InstallShield is only intended for DLLs that are not only distributed by MSIs (esp. MSMs), but by other install programs as well. The Windows Installer will update the SharedDLLs refcount as well.
You can enumerate all packages that installed the same component using the MsiEnumClients function. (I don't know how this function behaves with multiple users installing the same product... Requires some testing I guess).
