We have a problem:
Our install works fine when running from the network, but when we burn it to CD it doesn't. The problem is with an .ini file we have along with the install files. We have a custom action that reads this .ini file and copies a line, based on what install options are selected, into another .ini file we create in the install directory. We have no explanation for why it works from the network, but not off of a CD.
Any thoughts/suggestions?
Thanks in advance,
Scott
Works on Network, not on CD
schweitz77
, Feb 03 2003 22:40
Posted 04 February 2003 - 12:29
Does a log file reveal any information?
Posted 04 February 2003 - 15:28
No, it says the action runs, but it isn't doing anything.
Action start 8:12:11: MoveINIFileSettings.
MSI (s) (60:A4): Creating MSIHANDLE (96) of type 790542 for thread 420
Action ended 8:12:11: MoveINIFileSettings. Return value 1.
Here is the action(installscript):
function MoveINIFileSettings(hMSI)
NUMBER iValue, nSize, nVal;
STRING sFilePath, sSection, sKey, sResult, sSDir, sTDir;
begin
nSize = 255;
sSDir = "";
sTDir = "";
iValue = MsiGetProperty (hMSI, "SourceDir", sSDir, nSize);
iValue = MsiGetProperty (hMSI, "INSTALLDIR", sTDir, nSize);
nSize = 6;
iValue = MsiGetProperty (hMSI, "INSTALLLEVEL", sResult, nSize);
StrToNum(nVal, sResult);
if nVal = 100 then
//Network
sKey = "SettingsN";
elseif nVal = 200 then
//Standalone
sKey = "SettingsS";
else
//Defualt to Standalone
sKey = "SettingsS";
endif;
sSection = "Config";
sFilePath = sSDir ^ "SetupBVS.INI";
iValue = GetProfString(sFilePath, sSection, sKey, sResult);
sFilePath = sTDir ^ "BVS.INI";
sKey = "Settings";
iValue = WriteProfString(sFilePath, sSection, sKey, sResult);
end;
Thanks for your reply, maybe you can see something in this code that I am missing.
Scott
begin
nSize = 255;
sSDir = "";
sTDir = "";
nSize = 6;
if nVal = 100 then
//Network
sKey = "SettingsN";
//Standalone
sKey = "SettingsS";
else
sKey = "SettingsS";
endif;
sKey = "Settings";
end;
Scott
Posted 04 February 2003 - 16:23
i do not see where the sTDir is getting set to anything other then a null string ?
is it possible that this is assuming the cd root drive and due to read-only access can not perform this operation ?
Posted 04 February 2003 - 16:31
After this line:
you should insert
nSize = 255;
MsiGetProperty sets nSize to the number of character it has retrieved. If your SourceDir is shorter than your INSTALLDIR it will be cut off in in the next call.
you should insert
nSize = 255;
