Internal error 25001
oliver
, Sep 05 2003 14:43
oliver
oliver
Members
Posted 05 September 2003 - 14:43
Please help. I always get the error message 'Internal error 25001. 1615 Registration Costing::CostAllISelfService::MsiDatabaseOpenView(.....'. This error occurs at the beginnig of the installation after summary dialog. You can continue setup but i must know what i can do to avoid the error message and the reason.
Did some deeper research. Found out that the problem does seem isolated solely to the Merge Modules supplied by Delphi. I loaded a totally different installer program and added the Delphi 7 Merge Modules (BaseRTL, BaseVCL and SampleVCL), then installed the new program and encountered the exact same errors. So, our attentions should be focused on Borland to get them to correct the problems.
I talked with someone at a Borland Newsgroup and he gave me the following web address that explains the exact cause of the problems regarding Selfregistration:
