I have a MSI with 3 features. when i uninstall the product only the default feature is removed with other two remaining. any knows why?
Feature is not removed after uninstall
lis_ck2000
, Jul 08 2004 07:16
Posted 08 July 2004 - 07:47
Could be caused by any number of things.
Try running the uninstall with log mode. This should point to the cause of the problem. Specifically look at the feature states after install validate.
Posted 08 July 2004 - 13:21
Maybe the application writes some files at runtime that are part of these features and will not remove them.
Posted 09 July 2004 - 05:43
You need a log file for this:
http://www.appdeploy...etail.asp?id=73
http://www.appdeploy...etail.asp?id=82
