HI,
After creating setup.exe and if you right click and select Property then on Version's Tab, there are list of items that are displayed like, File version, Company Name, File Version, Internal Name, Product Name, Product version in the list box. I want to change this information as per my project.
Can anybody hass any idea on this.
Thanks in advance.
Rahul
Change information of setup.exe
rahuld
, Sep 22 2005 19:07
6 replies to this topic
Posted 07 November 2005 - 04:47
I have the same problem,
have you solved that problem,
if you did,please tell me , Thanks a lot!!!
Posted 07 November 2005 - 07:30
I believe this information is for Installshield since it is their bootstrapper. It may, however, be possible to change this information if you open the setup.exe as a resource file in Visual Studio.
Posted 08 November 2005 - 02:50
thanks a lot.
I have try it . I can open the resource of the setup.exe, but if I change the data,
the setup.exe can't run.
Strangetly, I can change the other exe file's resource by this way. I think it seems that
installshield has some mechanism to protect the setup.exe.
Posted 08 November 2005 - 11:49
I am not sure if this is a custom protection feature, or just happening because the date should also be changed for the file attributes themselves and not just for the internal version number. Maybe try using a tool to change the file's actual create/modify date and then change the internal date to match the file date itself.
Posted 09 November 2005 - 02:00
Please note that you may be violating the Installshield EULA by modifying the setup.exe like this. At the very least they will probably not provide support for your setup if you do this.
