Hello, How you doing?
When I "Edit the default installation location", I do not want to install the application at the "ProgramFilesFolder", I tried to create a folder named "PV", this folder is parallel to the ProgramFilesFolder. I set the INSTALLDIR under this "PV" folder. I do "build installations" and generate the installation file. When I run the installation file, the default installation shows to be "D/PV/application". I tried at some of my friends' computer. Sometimes, it is on "C/PV/application". It seems that the destination disk is randomly chosen.
Could you tell me how to set the default installation location to be at "C/PV/application" all the time?
Thank you so much~
How to set the default installation location
joeychou1985
, May 03 2010 15:10
Posted 03 May 2010 - 15:38
Do you really mean
D/PV/application
or
D:/PV/application
I mean: is the missing : the problem? Or that it sometimes installs on the D: drive instead of the C: drive?
You could check the Directory table to see what is selected as the parent for the PV folder. To force installation to the C drive you could add a custom action (type 51 - set a property) that sets the destination proeprty of this folder. Insert this custom action in the InstallUI and I´nstallExecute sequences before CostFinalize each.
BTW in general it is recommended to install to a subfolder of the ProgramFilesFolder.
D/PV/application
or
D:/PV/application
