If I add a new component to an existing feature, do I have to change the Product Code for updating. That's what I gather from the WI SDK.
Any help is greatly appreciated!
Changing the Product Code
Superfreak3
, Jan 08 2007 17:43
Posted 08 January 2007 - 18:21
Adding a component isn't a problem, you don't need to change the product code. Only removing a component is a problem.
If you are using msi runtime 1.x you must add a new (can be invisible) feature for the new component. This is not required with MSI 2.0 or above.
