Migrated a project created in IS Express 4 to IS DevStudio 9 basic msi project.
Building the project gives followin errors :
Building CAB files...
Data1.cab built
Files built
ISDEV : fatal error 0:
Express\SingleImage - 1 error(s), 0 warning(s)
Log file has been created: D:\achal\DevStudio\ProjectFW\Express\SingleImage\LogFiles\10-18-2003 02-04-00 PM.txt
What could be the cause? We even tried Building a blank project but result is same.
ISDEV fatal Error 0
ninadbhise
, Oct 20 2003 08:04
Posted 20 October 2003 - 10:58
One possible cause is use of an invalid RTF file in a scrollable text field on a dialog (typically the license agreement dialog).
http://support.insta...ticleid=q107879
Posted 10 July 2008 - 21:49
It is just that some icons like setup icon and uninstall icon's property has default 0 index set with the icon referenced from installshield folder "C:\Program Files\InstallShield\2009\Redist\Language Independent\OS Independent". Just copy and paste it in your folder and give all icon references to you project icon files only. This will remove all "ISDev error: 0: " error. I faced same error and removed it just by doing that.
Posted 20 October 2010 - 15:30
I'm running into the ISDEV: fatal error 0: problem. I have looked into the two issues mentioned here, but have not found a solution. I am getting this at the end of my verbose log:
Performing Upgrading and Patching Validation
Running Validator Val0002
Running Validator Val0005
Running Validator Val0008
Running Validator Val0013
No database is open. Illegal operation.
Any ideas? What do is meant by the previous post about copying icons?
Any help would be much appreciated!
Kevin
InstallShield 2011
Kevin
InstallShield 2011
Posted 20 October 2010 - 20:01
I found that this error was being caused by setting the disk folder to build on a network drive. This caused not only the Memo error for the license file but also the ISDEV : fatal error 0: .
Hope this helps someone else.
Kevin
Kevin
