Hi there,
We have here a program (written in C++) that once it should start msiexec. exe to install a .msi file. We start msiexec.exe in quite mode and we pass the parameters something like this
msiexec.exe /i "abc.msi" /qn /li "logfile.log"
We start msiexec.exe as a child process for our program. Everything runs OK until we want to stop the installation from our program. It is required that our child process (msiexec) can be stoped from our program.
Simply kill msiexec process is not a solution because it will leave the system in an unstable state. A solution would be to send a close message (WM_CLOSE) or a close signal to msiexec application but question is how and which one?
Any ideas?
How to stop msiexec.exe?
dodoSturm
, Aug 29 2003 18:46
Posted 01 September 2003 - 23:17
I am not sure how you can stop if gracefully, but why do you need to stop the install?
Maybe you should acutally code this logic into the installer, and not the program that kicks of the executable, then windows installer will handle the abort properly.
Posted 02 September 2003 - 09:10
The only solution I can think of is replacing the UI. By doing so, you get all kinds of notifications, and you can abort the install during such a notification.
Look at the docs on MsiSetExternalUI.
