Hi.
I am using InstallShiled 12 Express version. Is there any way to make requirement for the .net framework (as e.g. proceed only if at least version 2.0 is installed)?
Tnx
gligi
.NET Framework
gligi
, May 14 2007 11:51
Posted 15 May 2007 - 07:44
U can try this in OnBegin Function
Change the version name from 1.1 to 2.0 and see if the registry contains such value in ur local system and then write the code
U can go to the registry by RUn->Regedit
if (! MAINTENANCE) then
RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE);
if (RegDBKeyExist ("\\SOFTWARE\\Microsoft\\.NETFramework\\policy\\v1.1") < 0) then
MessageBox ("Kindly Install .NET FrameWork 1.1 before attempting eTouch Installation \n Installation will now abort.", SEVERE);
abort;
endif;
endif;
Hope this helps
Sreenath
abort;
endif;
endif;
Hope this helps
Sreenath
