Hi, I'm looking for some sample code that demonstrates the use of the WindowsInstaller API for changing a property in an MSI database. I'm trying to upgrate our build automation wizard (C++ Project) to set the version numbers on our products after each incremental test build. I've been looking at the sample directory in the MSI SDK but I need extra help.
Looking for samples for Build Automation in C++
Eric Pope
, Jan 05 2006 22:02
Posted 10 January 2006 - 19:04
So today I was looking at the vb scripts that come with the installer sdk and I tried to make my own script that would change the Properties, ProductVersion value. Something odd is happening. It looks like I changed the version but when I open the msi in orca it shows the original version. I can change the version to some random string and it gets saved domewhere but apperently not in the msi database file. Where is it getting saved I wonder?
Sample input / output (I tested my script on the orca.msi file)
C:\MSI386.SDK\Tools\versionbump.vbs orca.msi 1.222
Old Product Version: 1.10.1029.1
New Product Version: 1.222
and i double check to see if it really changed:
Then looking in Orca it is still the same number: 1.10.1029.1
I also checked the registry entry for the orca application thinking maybe the version number was getting saved there but it was the original 1.10.1029.1 too. So I changed that to 1.10.1029.1ep to see if the number in orca would change... but it didn't.
Posted 10 January 2006 - 20:24
Disregard last post, the problem was I was looking at the wrong file
How embarrassing!
How embarrassing!
