Hi i got custom action
Type: 6
and i add my script to Binary table
now when my script is called i get 1720 error. My script is simple only MsgBox("Say Hi!")
what is the problem?
VBScript
joker_pl
, Nov 02 2005 13:35
Posted 02 November 2005 - 20:23
I have a very similar issue. I'm storing the VBS in the binary table.
I want it to run on uninstall only.
sync (ignore exit code)
deferred execution
always execute
no
<absent>
After ScheduleReboot
REMOVE~="ALL"
deferred execution
always execute
no
<absent>
REMOVE~="ALL"
Edited by turbokitty, 02 November 2005 - 20:59.
Posted 10 November 2005 - 10:21
Does the script run successfully outside your setup? The error message indicates that there's a syntax error or something like that. The error message should also tell you in which line and column of your script, and what the error code was.
