status bar
Posted 11 February 2002 - 18:12
to solve this?I want the status bar to reach 100 only after all three components are installed.
Posted 11 February 2002 - 22:07
// SETUP DEFAULT STATUS
SetStatusWindow(0, "");
Enable(STATUSEX);
StatusUpdate(ON, 100);
I do this at the very end of OnFirstUIBeforeN( ).
Also, if you're doing any manual file copies, you need to do some things to the status bar. 'cause otherwise, I remember reading somewhere that the status bar will jump to 100%.
Posted 12 February 2002 - 05:53
when the first component data is transferred status bar becomes 100.Then on installed event of that
component is being called.After this when it is trying to transfer the next component the status bar is not reinitializing ,still showing 100.
Posted 12 February 2002 - 06:22
status bar from jumping to 100.
Posted 12 February 2002 - 15:34
StatusUpdate(OFF, 100);
// COPY FILE
Of course, the other solution is to simply postpone your file copies until AFTER all the components have been transferred.
Posted 14 February 2002 - 09:44
