Dear all,
When creating a path, does the modification of dialog sequence will cause the prompt for source file to occurs ?
For instance I have remove some dialog from original project and leave only minimum user dialog for patching.
Thnaks for your help
Serge
HELP :Patch as king for source disk ???
calderaraserge
, Sep 13 2004 09:10
Posted 13 September 2004 - 09:52
No, I don't think that would cause source file dependencies. There are many causes of source file being needed during patching. If you set the patch to include only full files (instead of bit level patching), this helps to reduce the number of source file dependencies.
