The setup was "blocked" on Win98 SE, but I generated the log:
=== Verbose logging started: 02/03/05 15.21.59 Build type: SHIP ANSI 1.10.1029.01 Calling process: C:\WINDOWS\SYSTEM\MSIEXEC.EXE ===
MSI © (E7:1B): Resetting cached policy values
MSI © (E7:1B): ******* RunEngine:
******* Product: D:\LDS.msi
******* Action:
******* CommandLine:
MSI © (E7:1B): No info for thread FFFB941B
MSI © (E7:1B): Did not find item Products\(NULL)
MSI © (E7:1B): Searching for item Products\(NULL) in per-user non-managed key
MSI © (E7:1B): Searching for item Products\(NULL) in per-machine key
MSI © (E7:1B): End dialog not enabled
MSI © (E7:1B): Original package ==> D:\LDS.msi
MSI © (E7:1B): Package we're running from ==> C:\WINDOWS\TEMP\61ee8f5.msi
MSI © (E7:1B): Searching for item Products\236BA67F4DAB7FF4488CF39648440B6F in per-user non-managed key
MSI © (E7:1B): Searching for item Products\236BA67F4DAB7FF4488CF39648440B6F in per-machine key
MSI © (E7:1B): Did not find item Products\236BA67F4DAB7FF4488CF39648440B6F
MSI © (E7:1B): Machine policy value 'TransformsSecure' is 0
MSI © (E7:1B): User policy value 'TransformsAtSource' is 0
MSI © (E7:1B): Transforms are not secure.
MSI © (E7:1B): Product Code passed to Engine.Initialize: ''
MSI © (E7:1B): Product Code from property table before transforms: '{F76AB632-BAD4-4FF7-84C8-3F698444B0F6}'
MSI © (E7:1B): Product Code from property table after transforms: '{F76AB632-BAD4-4FF7-84C8-3F698444B0F6}'
MSI © (E7:1B): Note: 1: 2729
MSI © (E7:1B): Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI © (E7:1B): Machine policy value 'DisableMsi' is 0
MSI © (E7:1B): Machine policy value 'AlwaysInstallElevated' is 0
MSI © (E7:1B): User policy value 'AlwaysInstallElevated' is 0
MSI © (E7:1B): Running product '{F76AB632-BAD4-4FF7-84C8-3F698444B0F6}' with user privileges: It's not assigned.
MSI © (E7:1B): TRANSFORMS property is now:
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Application Data
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Preferiti
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Risorse di rete
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\Documenti
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\PrintHood
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Recent
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\SendTo
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\ShellNew
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\All Users\Dati applicazioni
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Impostazioni locali\Dati applicazioni
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\Documenti\Immagini
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Menu Avvio\Programmi\Strumenti di amministrazione
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Menu Avvio\Programmi\Esecuzione automatica
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Desktop
MSI © (E7:1B): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\FONTS
=== Inizio registrazione: 02/03/05 15.22.08 ===
MSI © (E7:1B): Machine policy value 'DisableRollback' is 0
MSI © (E7:1B): User policy value 'DisableRollback' is 0
MSI © (E7:1B): Doing action: INSTALL
Inizio operazione 15.22.08: INSTALL.
MSI © (E7:1B): UI Sequence table 'InstallUISequence' is present and populated.
MSI © (E7:1B): Running UISequence
MSI © (E7:1B): Doing action: EngineStartup
Inizio operazione 15.22.08: EngineStartup.
MSI © (E7:1B): Creating MSIHANDLE (1) of type 790542 for thread -289765
1: extracting engine MSI file
1: Installing kernel files
1: scpthdlr.dll
1: After file installation, return code = 4608
1: ikernel.exe
1: After file installation, return code = 7
1: iuser.dll
1: knlwrap.exe
1: After file installation, return code = 0
1: msihook.dll
1: objectps.dll
1: Installing script engine
1: iscript.dll
Fine operazione 15.22.08: EngineStartup. Valore restituito 1.
MSI © (E7:1B): Doing action: StartUp
Inizio operazione 15.22.08: StartUp.
MSI © (E7:1B): Creating MSIHANDLE (37) of type 790542 for thread -289765
Win98 4.10.2222A + IE6 SP1
The setup made with ISWI 1.5 (Windows Installer 1.10)
Please, help me.
There's a problem of InstallShield script again?
gloom
, Mar 16 2005 14:06
Posted 18 March 2005 - 11:45
I don't see any error message abot "blocked" install in your log. Please describe the exact symptoms. Do you get any error message?
