I've got a type34 CA (trying to) launch a pdf file but I keep getting internal error 2743. Anyone had luck launching Acrobat? If so, how'd you do it?
Launching a pdf file
Kate
, May 01 2001 23:44
Posted 02 May 2001 - 14:15
Hi Kate,
I think you can try to find executable file of AdobeAcrobat on the target system and then launch you file. Do so:
1. Create in Power Editor\Signature a line like:
Signature: Acrobat
FileName: AcroRD32.exe
2. Create in Power Editor\DrLocator
Signature: Acrobat
Depth: 20 (or less this is depth for file search)
3. Create in Power Editor\AppSearch
Property: ACRORD
Signature: Acrobat
4. Create CA to launch you file
Source: ACRORD
Target: [Pathtofile]
Indicate Location in CA Wizard "Stored in the Property table"
Signature: Acrobat
Signature: Acrobat
Property: ACRORD
Signature: Acrobat
Source: ACRORD
Posted 02 May 2001 - 19:53
Thanks Irina! Worked like a charm.
Also, just additional info about Acrobat...apparently Acrobat doesn't like long file names. I put quotes around the whole target and then it worked fine.
