Hi Stefan,
I already create one msi project, when install new version, will manual uninstall old version and reinstall new version.
In current version, have one issues during uninstall, so I need create one upgrade version to replace old version.[Can't do uninstall]
The old msi is a. msi, the upgrade version also is b.msi. Only change one file , add one upgrade item and change the package code.
After install a. msi, then click new "b.msi". It will popup dialog, say "Need uninstall previous version first."
If I make the upgrade as setup.exe, then it is ok.
Could you please tell me why?
Juck
One Upgrade Question
juck
, Feb 08 2005 04:52
Posted 09 February 2005 - 15:14
What you're trying to do is a Minor Update.
First: you cannot change the name of the msi file in a Minor Update, so the new version must also be called a.msi.
If you don't want to use setup.exe you must launch the new version with comand line parameters:
msiexec.exe /i a.msi REINSTALLMODE=vomus REINSTALL=ALL
