A colleague has built an MSM which has the following dependency:
Name: Microsoft .NET Framework (Reference Only)
Version: 1.0
Language: English (United States)
Module ID: mondo.E4183BB4_18A8_11D5_A549_0090278A1BB8
When building I get:
Adding Microsoft® .NET Framework redistributables to setup...
ISDEV : error -1007: Cannot copy source 'D:\Builds\Your Project Name-1\Product Configuration 1\Interm\MergeModules\mondo.E4183BB4_18A8_11D5_A549_0090278A1BB8\Accessibility_dll_1_____X86.3643236F_FC70_11D3_A536_0090278A1BB8' to target 'D:\Builds\Your Project Name-1\Product Configuration 1\Release 1\DiskImages\DISK1\Win\Microsoft.NET\Framework\URTInstallPath\GAC\Accessibility.dll'
It makes no difference when I add in the .NET framework 1.0 or 1.1 to the release.
I'm using Developer 8 SP2.
It's an InstallScript MSI project.
OS: Windows Server 2000 SP3.
Any thoughts as to why I'm getting this error?
Thanks for your time,
Marc
delamere
, Jan 02 2004 18:17
Posted 02 January 2004 - 21:12
I believe this merge module is not intended for your distribution release. Check the Visual Studio documentation.
Posted 05 January 2004 - 14:55
Thanks for that Stefan.
We have now solved the problem.
The specific solution was to simply rebuild the MSM without .NET Framework 1.0 as a dependency - we are only using 1.1 anyway (but I don't know why that didn't appear as a dependency).
Regards,
Marc
Regards,
Marc
Posted 14 February 2006 - 13:02
hi,
i have the same problem on build a MSI from a ISM.
unable to copy file from ...\breakdown_group_id_tr_txt.kobra-data-dictonary to ...\.
The file is the first of many files with this fantastic extension
anybody an idea to copy this files? (copyFileTable will not copy files with this extension, i think)
Many thanks in advance!
greetings meg
EDIT: Solution, rename file, copy Rename ...?? very ugly ....
greetings meg
Edited by megael, 14 February 2006 - 13:52.
