I am trying to create an ODBC Data Source to an SQL Server instance by authoring the ODBCDataSource and ODBCSourceAttribute tables.
However I am nowhere near successful. I do not even get errors, just no Data source shows up. I am using Visual Studio Installer to make the basic msi file, then a collection of our own scripts to add in the extra functionality we require.
The ODBCSourceAttribute table looks like this
(DataSource Attribute Value)
ZAIMU_DATA_SOURCE Server [SQLSERVERNAME]
ZAIMU_DATA_SOURCE Trusted_Connection Yes
The ODBCDataSource table looks like this
DataSource
ZAIMU_DATA_SOURCE
Component_,
ODBC_ZAIM.A94FF93D-8E59-490A-AC3E-9C907DAA4484
Description
[ProductName]のデータソース
DriverDescription
SQL Server
Registration
0
The Component Table looks like this
Component
ComponentID
Directory
TARGETDIR
Attributes
32
Condition
(blank)
KeyPath
ZAIMU_DATA_SOURCE
I am not installing a driver, because I believe that if MDAC is installed the driver will reside on the system. I have tried various combinations in the DriverDescription field of the ODBCDataSource table, including the path to the driver dll but it hasn' t worked yet.
The MSDN "documentation" is on this is so flimsy, we might call it lingerie.
Can anyone help me?
Justin
SQL Server ODBC Data Source
jhunt
, Mar 08 2005 10:44
Posted 08 March 2005 - 12:13
OK I fixed it myself. First I downloaded 492mb of InstallShield Pro demo version. Then I created and installaer with an ODBC data source and opened the resulting MSI up in ORCA.
The main problem was that though I had added the component I had not added the component to the FeatureComponents table. Once I had that fixed I noticed that the ODBCDataSource Description field is in fact the name of the ODBC data source as it appears in Windows. The actual description is an attribute that needed to be added to the ODBCSourceAttributes table.
eg
"Description" "My very difficult to create odbc data source"
eg
