/JM switch install for all profiles
chrismillar
, May 06 2003 13:04
Posted 06 May 2003 - 13:04
Hello, I hope someone can help.
I have an MSI file that installs an application and registers COM+ components made in Express. I want to be able to have it installed for all profiles. So I found that using the /JM switch on msiexec /JM "package.msi" Sets the setup to install on all profiles. I then ran the setup and it did indeed install the files desktop shortcuts appeared etc.. However if I then tried to run the application on a profile that had just 'users' permissions i get the following error:
The application failed to initialize properly (0xc0000022).
However, when I change the access right to that user to administrator and then run it works, and then if I set the user back to 'users' member it then still works..
Any Ideas??
Posted 07 May 2003 - 15:08
have you tried setting it to an elevated process install using the policies ?
