Creating a hyperlink
sahana
sahana
  • 7 posts
Posted 04 June 2008 - 14:33
The problem i am facing is:Creating a hyperlink to redirect to
microsoft website to download .NET 3.5 using InstallShield 12.
Posted 05 June 2008 - 13:15
Are you talking about adding a "hyperlink control" to a dialog which the user should click to download the framework manually? Or should your setup automatically download and install the framework if it doesn't exist on the target machine?
In the first case: I don't think there's a hyperlink control. Also, installing the framework from within your MSI setup isn't possible (because the framework uses MSI itself). So you would need to create an executable that would download and install the framework and then launch your msi setup.
In the second case: InstallShield's setup.exe can do this for you. That's what "setup prerequsites" are for. Version 12 doesn't include a pre.build prerequisite for .NET 3.5 so you would have to build your own prerequisite using the prerequisite editor (or upgrade to InstallShield 2009)
