I wrote a free MSI to XML converter.
Check out
http://www.linkcad.c...xml/msi2xml.htm
if you are interested.
dgehri
, Apr 25 2001 18:53
Posted 26 April 2001 - 14:10
I just posted an update. So, if you had problems running the first release...
I also added the sources to my website.
Posted 02 May 2001 - 18:38
I also added the second tool to convert the XML files back to MSI.
It features column type validation, MD5 checksum validation and more. It will recreate an exact copy of the original .msi that has been converted to XML with msi2xml.
Sources and updated documentation will be available later this week.
Posted 03 May 2001 - 00:21
The sources for both, msi2xml and xml2msi are now available, and the documentation has been updated.
http://www.linkcad.com/index.asp?in=/msi2xml/msi2xml.htm
