Detect cancel button has been hit
austin2359
austin2359
  • 2 posts
Posted 10 November 2010 - 23:02
When the user hits "cancel" and the install backtracks, is there a way to detect this programatically?
Does it alter a temporary file, alter the registry, or launch/kill a hidden process for example?
Edited by austin2359, 10 November 2010 - 23:02.
Posted 11 November 2010 - 11:05
If setup is cancelled between InstallIntialize and InstallFinalize, the Rollback custom actions will be executed. Maybe you could use those to do whatever you need.
And the msiexec.exe exit code would be 1602 if the user cancelled the install (there are other codes to indicate failure etc. - see topic "Error Codes" in the documentation).
