I need to change the output path where the setup.exe will be created.
The release folder will create it in some path defined by installshield 10.5 but I want it to be placed in a shorter path.
Is there a way to do it or is the Release wizard the only way to create the output path for my setup.
Regards,
vishal
Changing the release path
vishalv
, Sep 19 2006 14:13
Posted 07 September 2007 - 15:04
I can't find a way to do this.
Even if I change "Release Location" to <ISProjectFolder>, the Installer insists on creating all the extra folders (i.e.
<ISProjectFolder>\<Product Configuration>\<Release Name>\<diskimage>\<disk1>\
Does ANYONE know how to force the installer to place the setup.exe in a folder withOUT all these extra folders being created?
Posted 07 September 2007 - 15:18
Found a solution\workaround.
If you want "setup.exe" to be placed in another location other than "..<Product Configuration>\<Release Name>\<diskimage>\<disk1>\" then you need to add "Distribute after every build" and a location for that distribution.
steps:
1. load .ism in installshield
2. change view to Installation Designer (tab)
3. left pane, under "Media" select Distribute
4. middle pane, select the release you wish to distribute
result: right-pane shows the distribute view
5. make sure "Folder" is selected, place location you want "setup.exe" to be placed
and make sure you select (x) "Distribute after every build"
Now when you build, you will get a copy of your setup.exe (or whatever you named it) in the location you want.
steps:
