Firstly, I'm using the web project deployment/installation feature of .net
I have added a gui form that has a checkbox, asking the user if they'd like to install MSDE as well. If the user checks this box, I would like the MSDE installation to be run before the rest of the original installation takes place. (I read on a microsoft page that they now prefer you to call a products installation from within an installation, as opposed to using merge modules.)
Anyway, how do I go about this? I was able to launch a test exe file during the installation if the user checked the check box by adding the exe as a Custom Action (Install folder) and setting the condition as the checkbox. However, I havent been able to add an msi as a custom action.
Thanks for any help
ps: also, is it possible in a web project installer to add a gui form to set the path to install the web project? for example I have IIS running on another hard drive and would like to be able to select which drive to install the project to.
Thanks again
Run another msi from within an msi
Target Audience
, Jul 13 2003 03:29
