Change/Remove are only possible if the original MSI package is found. If not, a browse dialog is opened. If cancelled, error 1703 happens.
Under which circumstances is the original MSI package required for change/remove?
Change/Remove always requires MSI package
standre
, Aug 04 2006 11:59
Posted 04 August 2006 - 18:19
There can be many reasons, for instance your setup may include a ResolveSource action that's not properly conditioned.
Posted 07 August 2006 - 09:55
Yepp, thanks. It was caused by a unconditional RemoveSource inside a merge module.
